Intermittent Miss
Posted by Brian Jensen on October 03, 2007 at 14:53:49 from (207.176.229.92):
Got everything back together again.... I seem to have an intermittent miss, there is absolutely no pattern to it at all. Could this be a distributor shaft wear issue? Since I have the timing set amongst the million other things I have done in the past 2 days. It seems to Want to start and stay started it just won't for some reason. Also when this miss occurs it seems to actually bog the starter down where it kind of hesitates due to the pressure. Again, all suggestions are appreciated.
