Re: Hydraulic Update
Posted by Brian Jensen on October 05, 2007 at 11:28:39 from (207.176.229.92):
In Reply to: Re: Hydraulic Update posted by El Toro on October 05, 2007 at 11:13:24:
Yes they are, I bought a new oil pressure guage from Wal Mart because the one I had didn't work, but the replacement line it came with it had 3 different fittings but the only way I could get them to fit was backwards but that made it so I did not a fitting to hook onto the line. so I put it together and capped it with a bolt, but it seems to be leaking right at the block. Maybe it is just loose but if I am fixing it, then I may as well fix the whole run.
