You need to hold your hand over the throat of the carburetor and see if there's good suction on your hand while someone makes an attempt to start the tractor. You need good intake manifold vacuum to pull that atomized fuel into the engine. Make sure the intake manifold is tight and the carburetor too. You may want to do a compression check on the engine too. Set the valve lash to .017" cold. You need good compression to have good intake maifold vacuum. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
