Re: 450D Day Time to check the Cam Gear!
Posted by Janicholson on October 11, 2007 at 12:00:49 from (199.17.6.122):
In Reply to: Re: 450D Day Time to check the Cam Gear! posted by Brian Jensen on October 11, 2007 at 11:37:22:
Those look good! Try moving the visible gear with your hand. It should have just a tiny bit of motion, maybe .002-.004". If the loader is up, Mark the gear teeth in some way to see if it moved, then try putting it in 5th TA forward, and rocking it back and forth. If it has no movement, Pulling the oil pan would be next.
The discovery so far would be that you did nothing "bad" to cause it!!! JimN
