Re: 450D Day Time to check the Cam Gear!
Posted by Brian Jensen on October 11, 2007 at 12:09:24 from (207.176.229.92):
In Reply to: Re: 450D Day Time to check the Cam Gear! posted by Janicholson on October 11, 2007 at 12:00:49:
Thanks Jim,
I did move it with my hand and it did move a tiny bit, the loader is down so moving the tractor in any way is not likely to happen unless I hook up a 4x4 to it and drag it. Should I put the hydraulic pump and distributor back before I pull the pan?
