Get an Operators Manual, it covers all that you asked about. You will need it in the future anyway when you need oil and greese info.
OEM sells the top generator tension bracket, part #60714DA, $13,50. The bottom one is kind of just U shaped with a short pipe on the left hand side. The might have used the old mounting bracket to mount the alt., that would have worked.
The top curved piece in Kieths picture is the correct tension bracket. The other ones pictured are not correct for the mounting bracket on any SA I have seen.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
