Re: I've searched - Any tricks on Super A fan belt removal?
Posted by ScottyHOMEy on October 22, 2007 at 19:07:24 from (71.241.212.142):
In Reply to: I've searched - Any tricks on Super A fan belt removal? posted by SteveNH on October 22, 2007 at 19:00:23:
Steve, you don't need notched belts.
HAve you tried slacking off the genreator brace to see if that gives you a little more wiggle to play with? If it was the right size to start with, the fan belt ought to slip right off the pulleys (easier doing top first) and then finessed out over the fan. Generator belt( if you don't have a water pump, meaning it's shorter than the one giving you trouble now) will take a little more finaglin' (like goin' over one fan blades at a time), but ought to come off the same way.
Worse comes to worse, put some corrugated cardboard over the back of your radiator to protect it and thread the fan shaft all the way out of the nut and drop the fan to get your belts off.
