I've searched - Any tricks on Super A fan belt removal?
Posted by SteveNH on October 22, 2007 at 19:00:23 from (64.222.148.108):
I"ve looked through the forum and saw that it is not fun... Loosen the nut on the back of the fan assembly and have at it. I tried and kind of failed. It is somewhat loose now, the assembly is as low at it will go, but I am afraid I am going to put something through the radiator trying to coax the belt off. Belt is in bad shape, not even sure if it is the right size and is going to be replaced anyway.
Does a new belt (right size belt) go on somewhat easy? if so I will just cut this one off. What belt size do I need? If not, is there a way to do this without taking the radiator and fan assembly off?
Do I need a cogged belt or just a regular belt I can get in the mower section at TSC? Same with the generator, I have the right size for the generator (allegedly) but it is cogged, not sure if it matters.
Your forum has been great help by the way,
Steve
