Re: IH 464 Running Hot
Posted by jjohnson on October 24, 2007 at 22:44:33 from (74.192.70.222):
In Reply to: Re: IH 464 Running Hot posted by georgeky on October 24, 2007 at 22:17:01:
Yes, I'm afraid so. If I run it with the 7# cap on, it will eventually boil over. Usually, I stop it before then, and it will boil over after I shut it off due to heat sink effect as the temp will climb to 230 or 240 degrees.
Thanks for the reply, though.
