Re: Belt pulley gearbox gasket
Posted by ScottyHOMEy on October 25, 2007 at 19:29:09 from (71.241.212.142):
In Reply to: Re: Belt pulley gearbox gasket posted by Roger46 on October 25, 2007 at 19:17:45:
Roger, could you ping me at skt4 at Columbia dot edu ?
I'm interested in what you said about sealing between shims. Got a persistent problem here with a leak at the right-side bearing where the shaft passes out of the tranny on my BN. New double seals and it still leaks. I'm thinkin' you might have my answer.
Thanks!
