Re: Belt pulley gearbox gasket
Posted by Roger46 on October 25, 2007 at 19:17:45 from (69.58.143.234):
In Reply to: Belt pulley gearbox gasket posted by Scott Rukke on October 25, 2007 at 16:50:14:
It appears you are talking about the output shaft of the belt pulley. As someone said below, the flange has shims on it to set the bevel gears engagement/backlash. If you do put a gasket in with the shims it will change the alignment and cause excess wear of the bevel gears. I have had problems with the shims leaking in the past. Someone posted a reply in the past saying that it is critical to get the shims clean including removing all rust. That way they seal the best. Also, I have coated each shim with a very thin layer of nonhardening gasket cement and that prevents leakage. Another point, if you put in a gasket it will not prevent leakage as oil can leak out between each shim. Roger
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
