Re: H starting issue(s)
Posted by El Toro on October 28, 2007 at 19:26:06 from (64.12.116.73):
In Reply to: H starting issue(s) posted by CJAA on October 28, 2007 at 17:47:00:
I would pull the sparkplugs and see if it will turn one complete revolution before pull starting. You could damage the drivetrain if the engine is stuck for some reason. Hal
