Posted by D Slater on October 30, 2007 at 06:47:50 from (71.182.17.176):
In Reply to: 450 steering wheel posted by David Robinson on October 30, 2007 at 05:59:43:
Most average pullers won't work,but if you have one that will the 450 steering wheel has 2 bolt holes that can be used with a puller for pulling steering wheel. If steering W. is a through away the plastic can be knocked off and hub heated or carefuly cut off from shaft. Recomend you loosen shaft collar and in front of U joint and slide shaft to rear some before doing that. Also after sliding shaft to rear some and with plastic removed from hub some pullers will work by catching behind hub.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
