farmall m hyd pump
Posted by leonard kostesky on November 01, 2007 at 10:17:25 from (208.74.24.77):
had a fellow bring me a belly pump/resivoir.pump housing was cracked,installed different pump obtained from wrecker.after swapping the pump, hyds work for a bit then lose pressure,until control lever on side of tractor is reset. Is this lever connected to releif valve? If so how is it set/tested?
