Re: farmall m hyd pump
Posted by the tractor vet on November 01, 2007 at 10:37:43 from (76.212.227.41):
In Reply to: farmall m hyd pump posted by leonard kostesky on November 01, 2007 at 10:17:25:
the pressure relief valve is a spring and ball deal built into the valve body . It can be serviced after taking the pump apart . All the control does is move the selector valve that tell the fluid where to go as OK i need to lift now or hold the cylinder where you want it or when ya shove forward it dumps the oil back into the sump. They did have a update package to raise the pressure on the old units up to i thing like 950 maybe 1000 psi. You would have to check with your Case IH dealer on that.
