Re: Fartmall H timing.
Posted by Mike Farmer on November 04, 2007 at 13:50:55 from (81.107.136.160):
In Reply to: Fartmall H timing. posted by Al Bowers on October 31, 2007 at 17:47:38:
If you haven,t pre marked it as per the photo then I guess you will need to take the timing cover off and line it all up as per the manual. A possible alternative is to ask someone with a running tractor to park close to yours and set his own at TDC and remove the mag. You then set yours at TDC and play with the mag until you get exactly the same line up. I wish I'd thought of that when I did the same thing a while ago. Mike Farmer MTF
