Re: 444 battery and various starting/electrical questions
Posted by IH2444 on November 05, 2007 at 05:46:06 from (192.76.82.89):
In Reply to: 444 battery and various starting/electrical questions posted by Casstuba on November 04, 2007 at 19:01:46:
The $$$ has a piece of resistive wire in the wiring harness that it uses to drop the 12V to 6V for the coil. Maybe you have a 12V coil (internal resistor) on it ?
Also the condenser in the dist can cause weak spark ?
Sounds like you might have a battery or charging system problem as well.
You local auto parts dealer can likely test the battery for you.
