Re: Hydraulics on a C
Posted by ScottyHOMEy on November 08, 2007 at 09:41:37 from (71.241.212.142):
In Reply to: Hydraulics on a C posted by lloyd1 on November 08, 2007 at 09:24:26:
Does your C have the Touch-Control already? I know you could get a Super C with either of two versions of hydraulics -- one was just Touch Control, the other was TC and remote. The major difference that allowed for remote was a different block at the back of the manifold that runs up to the pump, that allowed you to tap off pressure for the remote.
Even if you already have the Touch Control, I don't know if the Super C manifold for the remote, if you cold find one, would swap over to the C or not. If it does and you could find one, it would be a matter of adding controls for the remote and routing your hoses.
