Re: how to charge 6 v battery
Posted by John T on November 08, 2007 at 19:36:26 from (66.244.83.147):
In Reply to: how to charge 6 v battery posted by 1951farmallh on November 08, 2007 at 18:39:21:
Just hook the charger up the same way you always connect a charger or jump a battery + to + and - to - as glenster told ya, the charger dont care if you got some huge hunk of iron hangin onto one battery post or the other. One thing to be careful of, however, is if say youre jumping a Pos grnd tractor with a - grounded truck, dont let the frames get in contact
John T
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
