Re: how to charge 6 v battery
Posted by Hugh MacKay on November 09, 2007 at 09:55:23 from (216.208.58.163):
In Reply to: Re: how to charge 6 v battery posted by John T on November 08, 2007 at 19:36:26:
John: You got it, way back in 1965 I pulled my 1963 Pontiac up behind 6 volt, positive ground, Farmall 300 to give the 300 a boost. Tractor had a shidding winch with steel cable and a 1/2 dozen cable chokers. We had been skidding on hard frozen ground and those chokers were shined up like glass. As I was cranking the tractor one of those chokers fell on the car bumber. Luckily I was ahead of rear tractor tire. The tractor started as the car battery blew to bits. There was nothing left of the battery under the hood but the base. Most of the battery acid hit the barn wall beside us and back of tractor. We never did find 1/2 the battery. New battery and the car worked fine, I figured the alternator would be toast, but it worked until 1967 when I traded for anther new Pontiac. Never did that one again.
