Re: Farmall M....clunking noise.
Posted by Janicholson on November 10, 2007 at 06:35:42 from (66.173.50.26):
In Reply to: Farmall M....clunking noise. posted by WonderingAl on November 09, 2007 at 17:55:08:
Items not mentioned so far include the current oil pressure (if less than 20 PSI cold, and dropping from there it is not typical and indicates problems. If it has strong pulses in the needle movement at idle, it is also an indication of bearing failure.)
The changing of the oil should include a scraping around in the bottom of the pan with a wire to look for particles and shavings of metal.
Oil analysis can also be done professionally to assess material in the oil that indicates failure.
If it is in the "bottom" of the engine, it is probably a Main or rod, In that case it is an out of frame rebuild. JimN
