Re: Value of this 1938 F-20
Posted by CNKS on November 10, 2007 at 19:30:23 from (216.144.104.128):
In Reply to: Value of this 1938 F-20 posted by Scott Rukke on November 10, 2007 at 15:49:24:
The other problems are a lot worse than the pitting. Remove the rust, sanding, wire wheel, fiber wheel, etc., use a rust converter if there is still rust in the pits. Then use a 2-part body filler in the pits, sand smooth (easier said than done), epoxy prime, sandable surfacer over the epoxy, and topcoat. A LOT of work, but the pits will be covered.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
