Re: Have a few questions on fixing leaks on my 1943 H
Posted by William Stubbs on November 14, 2007 at 21:26:07 from (208.106.21.232):
In Reply to: Have a few questions on fixing leaks on my 1943 H posted by neblinc on November 14, 2007 at 06:27:00:
I too am rebuilding an H (1947) I made a few mistakes working on the brakes. I tried to pull the bull pinion without moving the bull gear. REsult was I broke the bull pinion. I was trying to remove the brake seal by using 2 mounting bolts as jack screws. Big mistake. If you can get the seal out without removing bull pinion hsg it will save time. The seal is 1" thick and no longer available. I put in 2 (total of 4) p# 416444. The seal on the axle is p# 25043 and is easy but you have to remove the wheel and that is no small task.
Bill, Northern CA
