Re: steering play on narrow M
Posted by little john on November 17, 2007 at 06:07:19 from (205.188.116.73):
In Reply to: Re: steering play on narrow M posted by Carden on November 17, 2007 at 05:35:19:
There are several things that can be involved in loose steering.....including the the u-joint, the worm gear at the front of the steering rod, the gear that you mention at the top of the steering pedestal, bushings in the pedestal, and wheel bearings. If you take off the cover at the top of the pedestal you can see if you have a full-circle gear or half-circle. If it is full-circle, you should be able to rotate it so you are using an unworn part.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
