Posted by RustyFarmall on November 21, 2007 at 05:37:42 from (66.43.253.19):
In Reply to: H Carb problem? posted by Stevishere on November 21, 2007 at 04:12:25:
The screw on the upper left is the idle air adjustment. It is supposed to be set at 1 1/2 turns out, and then adjusted after the engine is warmed up. The load, or high idle adjustment screw is the one at the very bottom of the carb. It is the the one that is set at 3 turns out, and very rarely will need any further adjustment.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
