Re: Steering connection problem con't, with pic
Posted by Owen Aaland on November 24, 2007 at 00:36:07 from (65.165.246.41):
In Reply to: Steering connection problem con't, with pic posted by Mike CA on November 23, 2007 at 22:56:13:
I believe the steering shaft support goes in front of the plate that hold the gauges. That way the grease zerk faces up so that it can be greased through the hole in the hood.
