Posted by Mike CA on November 23, 2007 at 22:56:13 from (76.239.186.148):
The problem persists, and I can't figure out why. I put the lower steering shaft in, screwed it in as tight as it would go, checked to make sure the bearing was seated as far as it could go, but the end of the shaft still comes up short. I've taken it out and retried 4 times. I've loosened the guide you see to the right of where the U-joint touches, but that didn't help. I marked where the center of the key's indent on the shaft and the end of the shaft IS in green, and SHOULD BE in blue.
Any ideas will be greatly appreciated, nothing has worked so far.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
