Re: Steering connection problem con't, with pic
Posted by Steven f/AZ on November 24, 2007 at 03:45:13 from (24.121.167.138):
In Reply to: Steering connection problem con't, with pic posted by Mike CA on November 23, 2007 at 22:56:13:
Steering shaft cast iron support is wrong - needs to be in front of the gauges like already said - grease zerk should face up so you can grease it through the hole in the hood.
Pictures truly are worth 1000 words!
