Re: Steering connection problem con't, with pic
Posted by Mike Farmer on November 24, 2007 at 05:22:53 from (81.107.129.227):
In Reply to: Steering connection problem con't, with pic posted by Mike CA on November 23, 2007 at 22:56:13:
All the points made are very valid.But! I think even when you turn that casting the right way up it won't make a lot of difference. I would try loosening the collars at the top of the steering columb under the throttle and then just slide the steering wheel end forward enough to make the connection that you require. The problem is that simple. Enjoy your day. Here its raining. MTF
