mike if you got wiring spaghetti, do like old says and hot wire it. if you are 6 v postive ground, run a wire from the neg on the battery to the coil, terminal opposite the one that goes to the distributor. use an alligator clip, so if it fires up, you can shut it down quickly. pull the coil wire or a spark plg wire , hook up the jumper and crank it over, see if you get spark. if you get spark, be sure tractor is in neutral, block the back wheels, set the throttle about 1/4 open, give her a quick snort of ether starting fluid and crank er over, she should pop on ether. if she pops, be sure the fuel is on, give er another quick snort and let er rip!!! if it fires up, it 'll prolly smoke some till she clears out, then let her run at a fast idle, keep yer eyeball on the oil pressure. if you dont get pressure shut er down quick. when all is good, have the wife and kids plan an escape route, climb aboard, select 1st or 2nd gear and go fer a zoom!!!!!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
