Posted by Mike CA on November 24, 2007 at 13:37:33 from (75.31.160.150):
Today was the first shot at starting up this H. I filled the radiator, and found out it has a pretty big leak. Put fuel in the tank, found out that my carb leaks at a couple places, and the sediment bowl valve leaks. But regardless, we pushed on to give it a shot. We hooked a 6v battery up and gave it a try... nuthin. Not even a burp.
The wiring is sort of odd. There is a VR hooked up to a weird spot, and a solenoid in the loop. It used some aftermarker push button, and also an up/down flip switch.
So, what I think I'm going to do is just rerun the wiring correctly. Fuix the fuel line, fix the sediment bowl, and fix the radiator.
I'm just bummed. I wanted to hear it fire up today. I really thought it would.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
