Re: Why I'm splitting the Super H
Posted by r4etired on November 25, 2007 at 17:44:40 from (64.12.116.73):
In Reply to: Why I'm splitting the Super H posted by GeneMO on November 25, 2007 at 17:16:44:
Some time in the life of the SH someone must have put a soft bolt in, the bottom 4 are 5/8 and the top ones are 3/4.I have seen pullers break the casting but never the bolts.The seals are an easy fix once you take the U joint apart.I don't have a SH service manual and agree with you about the IT manual.A parts book is about as good as anything most people have access to.Did I read a few months ago that you had a kidney transplant,My first one was in 92 the second in 97. Doing well with this one.If you run into problems just post again.
