Re: 350 Power Steering
Posted by G Johnson on November 25, 2007 at 20:27:17 from (24.2.103.110):
In Reply to: Re: 350 Power Steering posted by D Slater on November 25, 2007 at 17:29:58:
D Slater
I have a IH 300 utility that I got last year and it came with power steering, however it is doing the exact same thing as this 350. It only works when I am using the lift. Should I be looking for the same plug? I would appreciate any help, I have had this thing apart many times and I can't find anything damaged or broken.
Thank you
Gary
