Re: Add live hydraulics to M?
Posted by wh on November 27, 2007 at 09:42:24 from (208.61.210.228):
In Reply to: Add live hydraulics to M? posted by Carden on November 27, 2007 at 06:24:56:
i did the same thing to a "H". changed the front engine cover out to match the pump. used a cover from a 300 -- you may need a cover from a 400. there is a way to do it without changing. link will show my setup. i also built an external tank that holds 7 gallon of fluid.
