Re: 1940 H engine will not slow down to idle
Posted by tackhammertime on December 01, 2007 at 09:43:35 from (70.144.97.163):
In Reply to: 1940 H engine will not slow down to idle posted by tackhammertime on December 01, 2007 at 07:59:13:
Ok I found the procedure for synchronizing the gov. to the carb. this helped so I adj the carb per the service manual. Still boggs down when you let out the clutch in 5th gear but it idles great and gov. does increase and decrease engine speed when going up and down hills.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
