Posted by Bob M on December 04, 2007 at 06:15:05 from (151.190.254.108):
In Reply to: Super c wiring/lights posted by Need To Know on December 04, 2007 at 02:51:22:
First off there’s a wiring error somewhere - probably at the ammeter. If the wiring is correct, with the engine stopped and with the lights "on" the ammeter will indicate a bit over 10 amps discharge.
You'll need to find and correct the wiring error before proceeding. A wiring diagram for your Super C can be found as image #2 at the link below. (Note: The diagram titled for a Super H/M - however the Super C should be wired the same)
Once you have the wiring correct run the engine and see if the battery now charges. With luck you will have solved the problem.
However if the ammeter still shows no charge, work through the step-by-step troubleshooting flowchart at image #15 below to isolate the problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
