Re: Farmall H Battery
Posted by El Toro on December 04, 2007 at 16:55:52 from (64.12.116.73):
In Reply to: Re: Farmall H Battery posted by edward_m on December 04, 2007 at 15:52:56:
You should be getting around 14.0 to 14.5 volts at the battery with engine at 3/4 throttle. Hal
