Posted by r4etired on December 04, 2007 at 18:10:22 from (205.188.116.73):
In Reply to: super m head stud ??? posted by glennster on December 04, 2007 at 17:44:57:
The washers are under the 3 head studs that are next to the rockers, not under the rocker bases. They are used over the water jacket area of the head instead of the solid perimeter.The only situation I can think of is if your valves have been replaced with longer ones and the washers were used to compensate. I think you better check your valves.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
