Re: Farmall A spin on oil filter conversion kit
Posted by tractorsam on December 06, 2007 at 02:59:54 from (71.7.203.35):
In Reply to: Farmall A spin on oil filter conversion kit posted by Paul Mongillo on December 05, 2007 at 21:06:26:
I've worked on one of these tractors that had a spin on filter and it was shorter and fatter than the original cannister so you'd have a hard time ever making it look original. tractorsam
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
