Farmall A spin on oil filter conversion kit
Posted by Paul Mongillo on December 05, 2007 at 21:06:26 from (4.239.78.11):
Does anybody have any experence with the spin on kit for oil filters for a Farmall A, Can you hide the modern day filter with the oringinal canister? does the kit require a certain filter?
or can you still get the original filters? any help on this would be greatly appreateded
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
