Re: Farmall A spin on oil filter conversion kit
Posted by Hugh MacKay on December 06, 2007 at 07:26:24 from (209.226.247.76):
In Reply to: Re: Farmall A spin on oil filter conversion kit posted by georgeky on December 06, 2007 at 06:29:09:
George: That doesn't surprise me, and I'll bet the Super A is not far behind. The A may be starting to fall a bit behind not having hydraulics. 10 years ago there were a lot of offsets, parked in grandpa's barn, he didn't use it but he also wouldn't part with it. A lot of those are coming on the market as families part with grandpa's estate. I don't think the C, SC, 200, etc are far behind. Those little tractors, both sizes, are very popular with folks wanting a light tractor for yard work.
You think about it, often time you'll buy these for $1,500. to $3,000., maybe even a few implements for a bit more. Even if one has to spend $1,500. to put it in top shape. Once you have this done for under $5,000., maybe 6, you could count on quite economical operation for 25 years. Now, I ask you, stack that against a new compact Deere or Kubota.
If my yard work involved a bit of earth moving, I'd add a skid steer, and use the tractor to pull the trailer loads of earth. I've always found a skid steer one of the best cash cows to have around. There are always folks wanting material moved in tight quarters.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
