Re: Farmall A spin on oil filter conversion kit
Posted by georgeky on December 06, 2007 at 08:41:15 from (64.12.116.73):
In Reply to: Re: Farmall A spin on oil filter conversion kit posted by Hugh MacKay on December 06, 2007 at 07:26:24:
Hugh, you don't have to convince me, as you well know, I am a firm believer in those little gas tractors. There are still hundreds and hundreds of them around here working. Mostly cultivating duty, but working none the less. Lots of old tenant tobacco farmers have only a SA or 100/130/140 or two. They are probably the most dependable, long lasting tractors going. At least one of them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
