Re: How does one determine the difference between a Farmall
Posted by georgeky on December 14, 2007 at 21:40:20 from (205.188.116.73):
In Reply to: Re: How does one determine the difference between a Farmall posted by Hugh MacKay on December 14, 2007 at 16:01:03:
Hugh, I see I did give 55 casting code instead of 54. I forgot the 100 came out in 54. I was thinking 55 as the SA was made in 54 as well.
