Re: Farmall H snowplow ''floats''... oops
Posted by Guyzoo on December 22, 2007 at 07:29:08 from (142.166.228.173):
In Reply to: Farmall H snowplow ''floats'' posted by Guyzoo on December 21, 2007 at 17:41:59:
The plow is a hand made plow that my uncle build a long time ago and the hydraulics are fine (the plow is attatched to the hydraulic system with chains and they come loose when the plow toutches the ground.) the skid shoes are made of 90 degree angle iron welded to the edge of the plow. It was working great on my allis.
thank you very much your help is appreciated
