Guyzoo: Like your blade, mine also is chain lift, that is our float. I sense a bit of confusion on the thread, your blade is not mounted on a loader, right or wrong? As I understand it your push arms going back to axle housing on each side, am I correct? Can be used only with narrow front end, correct?
I had one like that on a Farmall 300 nf, I built a frame out from axle housings, put my pivot at roughly clutch. I don't think the pivot point forward or aft matters, just get it low enough, so the blade stands more upright. Maybe you can achive some adjustment at the blade end easier than lowering the pivot. I had to lower the pivot with my 300 blade also. On both the 300 and my 130, it was blade tipped too far forward at top. Causes blade to act like a sled runner.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
