Re: 450 cluth/tranny
Posted by Bill46 on December 26, 2007 at 10:25:07 from (65.200.157.177):
In Reply to: Re: 450 cluth/tranny posted by Hoss357 on December 26, 2007 at 10:16:09:
Hummm...in neutral it rolls....ok.
You got something bound up.
Just cause the clutch pedal goes down doesn't mean its released though.
Can you get a wrench or a crank on the engine and turn it? If push comes to shove, remove the starter and try to "gently" move the flywheel teeth a little. If it's a diesel...put the lever in gas position.
Are you sure the clutch plate it in right? Could it be reversed? The clutch plate has a cone on it. If it's in backward it might be bound up. Heaven forbid they gave you the wrong disc.
