Re: 450 cluth/tranny
Posted by Hoss357 on December 26, 2007 at 10:33:55 from (24.176.33.82):
In Reply to: Re: 450 cluth/tranny posted by Bill46 on December 26, 2007 at 10:25:07:
engine turns over...the last time i hooked everything up you could start in neutral but if you pushed the clutch in it would grind when trying to put it in gear... if you started it in gear it would want to move, but the brake would stop it....thats when i put the new clutch in and the t/a eliminator kit now it acts like its doing the same???
