Posted by Fromjb2 on December 29, 2007 at 13:24:27 from (99.241.179.24):
In Reply to: Re: B275 stops running posted by Daniel Hindry on December 29, 2007 at 11:55:48:
Daniel, if I remember correctly the injector trip pressure on the B414D was about 2200 PSI, so B275 should be the same. Becareful with the high pressure lines to the injectors as high pressure Diesel fuel can cause serious injury.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
