Re: Put in a TA into an early M
Posted by georgeky on December 30, 2007 at 21:16:17 from (205.188.116.73):
In Reply to: Put in a TA into an early M posted by az tractor guy on December 30, 2007 at 20:27:33:
TA will NOT fit in a plain M. You WILL need the whole MTA/400/450 rear end from bell housing back to do it. Engine, hydraulic pump and all that does not matter. In other words, you are better of buying a SMTA/400/450. The gears from an M will fit in those, but must be added in matching sets.(top&bottom) The so called SHTA's have 300 rearends in those, and H front ends. TA is in no way associated with the engine.
