Re: Put in a TA into an early M
Posted by Wardner on December 30, 2007 at 21:52:26 from (4.154.240.143):
In Reply to: Put in a TA into an early M posted by az tractor guy on December 30, 2007 at 20:27:33:
Unless you have a yard full of old IH product littering your property, you are talking about cubic dollars. There is no point in upgrading a M to SMTA capability because you will, in effect, destroy a SMTA by putting an old M motor in it. On top of that what are you going to do about hydraulics? Just get on with your life and own a stock SMTA, 400, 450, 560.
OK, having said that, let's get to the meat of your situation. You want a go-slow tractor. I like them too. I have a SMTA with a 560 differential, some 560 bearings, and 560 tranny gears (1st gear in particular). The TA works. The tires are 15.5 x 38. This set up gives me about 11-12 mph in top gear/high range. The rated speed of a SMTA is 16 mph. Low gear/low range on my tractor is at least 50% of low gear/low range of a SMTA. There is not much more that I can do without bolting up 660 planetary axles and wheels. That would really be "creepy". Top speed would be around 8 mph. Everything can be calculated with the parts books and knowledge of the loaded radius of the drive tires.
I don't think you need to go to this trouble. A TA equipped tractor starting with a 300 (skip 330 and 340) and going thru to 660 will run a rototiller. The 300 will run a five footer, The bigger tractors will probably run a eight footer. Bear is mind that there is a big difference between sod and previously tilled soil. Soil types make a difference too.
